Hello everyone ! New guy from Miami with a few questions and issues and hoping I get some good advise from the REEL pros. Because the pros I took it too are sitting back enjoying 1500 bucks and Im still not on the water yet... Anyhow , here it goes.
Boat-1983 Mako 254
Motors- Twin Yamaha 250's
What did 1500.00 get me at the shop.... Two trim motors , Spark plugs, and water pumps...
Problem 1- Port motor (after repair) only went up... After a 300 quote for new relay I got one myself and put it in now it works like a champ... Problem SOLVED
Problem 2- When Key turned to on position for PORT motor, STARBOARD motor trims up.
Problem 3- Port motor will not self test audible alarm when key turned on (and no gauges light up) Therefor will not start, all it does is crank. No start. So I got creative and Switched the ignition switch (key) to STARBOARD and then the PORT motor starts fine (including gauges but shown on STARBOARD side. Switched the STARBOARD motor to PORT side switch and it started the STARBOARD motor. So in affect, the POrT side ignition will start only the STARBOARD motor and the StaRBoard ignition will start either motor. So the PORT switch does not like the PorT engine... What could that be...
Boat-1983 Mako 254
