Re: need help with stator size
I don't have the specs so I can't answer all your questions, but here's some info fer ya that should help...<br /><br />The original black stators are no longer available. They were replaced with Red stators sometime in 1996. So your 1996 could have either. The black ones have 9 amp alternators and the red ones have 16. You can use a black stator with the larger 16 amp regulator, but not vice-versa. So if you have a black stator, you need a new regulator if you get the 16 amp Sierra.<br /><br />It's rare for either part to damage the other. The black stators had sharp edges from the laminating process that wore into the windings. Rapair takes those, smooths the edges, and rewinds them. Sierra parts are not rebuilds to the best of my knowledge. But in either case, that's the cause of many if not most black stator failures. Voltage regulators mostly go bad due to loose or corroded battery connections, or from the battery being connected backwards even for a split-second. So odds are that you have two related parts that failed for different reasons.
