Re: need help with repair
If you can see foam thru an exterior crack, you have a serious structural issue. Beside weakening the hull, the foam can become water logged which can cause loss of buoyance, add weight, and promote rot to the hull stiffener stringers and possibly the transom.
Best get profession advice.
