Need help with props
Newguy22
I have an etec 25 and have been trough two props now. What would make the blades on the prop bend forwards (toward the transom)? I had it out for an hour yesterday and the prop is bend forwards??
Any help would be greatly appreciated.
IamCanadian
Re: Need help with props
photo? Hitting bottom will make blades bend forward, like going through sand.
steelespike
Pictures would help. Is there no indication it is hitting something?
Is it a BRP prop? Aluminum or stainless?
Newguy22
It's a aluminum powertec 13 pitch. I don't know how to add pictures from phone.
steelespike
The only thing I can think of is a little slop in the shaft allowing the prop to slip out and hit the anode fin in reverse.
You probably need to use a hosting site to do pictures.
Again does the prop look like it is hitting something?
If you were to back through sand a or dense mud it might fold the blades.
Perhaps someone is messing with you.
Mi duckdown
Pics. Hitting someting will not bend the blades towards the transom. Confused.
Newguy22
It was a brand new prop when I put it on. I took it out for maybe and hour. I was in a little bit of sand on a sandbar for a minute but never put it in reverse. I'm confused too because if I would have hit something I would think it would bend the blades away from the transom.
IamCanadian
Powering forward through sand will bend the tips towards the transom.
Newguy22
hmm ok guess thats my problem then. i just didnt understand how it could bend it that bad in sand in les then an hours time on the water.
Mi duckdown
I guess I need to be corrected, cause I only hit ROCKS. lessen learned, I think.
jestor68
It only takes a few seconds pushing sand to do the job. There would also be some paint missing on all the blades equal to the depth the blades were immersed in the sand.
Ayuh,... Welcome Aboard,... as evidenced by yer prop,...
Props are for pushin' Water,...
Not dredgin' the sand, 'n rocks on the bottom...
