need help with prop size
screenbuzz
just bought a 1981 18 ft manatee with a 1985 evinrude. the prop is 13 3/4 by 15. cannot get the boat to plane out. the rpm's run way up at full throttle. the boat was once used for shrimping. what size prop do i need to get the boat to plane? any help greatly appreciated.
crazyray
Re: need help with prop size
If your engine is turning high rpm's and boat will not plane ..I would check hub of prop first.....sounds as if it maybe spun..
