sammy29926
- Jun 24, 2008
- 47
Hi,
Boat is a 2001 Larson 208 SEi with Johnson 150 on it. Since i bougth the boat fuel gauge did not work. After sending them to Faria for warranty work everything worked except the fuel gauge and today i had time to take the fuel sending unit out and find out what migth be the problem. after taking the sending unit out i took some readings and decided it was the source of the problem. It is a sliding type unit and when the float is on top it reads 33ohms and when i move it half an inch down it read 1ohm. So sending unit is the problem but there is no part numbers or manufacturer name ont heunit. I am attaching 3 pictures of th eunit and i really can use your help or advice which can direct me to order the right size sending unit. It is 7 inches long mesuring from the bootm to the bottom op the top flance.
thank you
Sammy
thank you
Sammy
