No spark on an early 90's BF8.
I have a Seloc manual and did all of the tests that it recommends. However, it does not have a chart for the BF8 to test the ignition module. It lists all of the other engines. How do I test this?
The resistance on the primary side of the coil is about twice what it should be. However, the reading jumps around a lot and it has read in the proper range. The secondary side is fine. Is there a more reliable way to test this?
The charging coil resistance is a little high, but I do not see how that could be causing the problem.
Also, when I pull the cord to start, the green oil light does not light up. The manual says the only way to test the oil pressure switch is with the engine running, which obviously does not help me out.
Finally, if I do have to replace the coil and the ignition, they are both pretty expensive. Any suggestions on outfits to get parts would be great.
Any ideas would be greatly appreciated.
Adam
Adam
