Need Help With My '97 Exciter 220
quadrunner08
i replaced the crank seals in the right engine of my '97 yamaha exciter. that engine now runs good, however. the right engine now fires with a turn of the key but immediatly looses spark. can anyone give me some tips on what direction to head? i check the teather, kill switches, and obvious connections.
Blade_Link
Re: Need Help With My '97 Exciter 220
im not too good with the newer motors, im guessing that your coils/ point/condernsers are worn, might have enough juice to start but not enough to run it. check those, of not look for a worn wire causing it to partally arc out to the head or else where, also try to disconnect your kill switch, you can always unplug the gasline to shut it down or pull the plug wires off.
let me know what happens ill do some research into this but im thinking its a minor electrical prob
Eshaw150
first off this motor does not have condensers points and theus only has coils
quadrunner08
i know it has only coils, both internal and external. i don't believe they would act in that manner though. the left engine does the same exact thing when i pull the tether off, so maybe i have a short somewhere in that circuit?
Eshaw150
that is a high chance but i was refering to blade links post
Eshaw150
you may need to post this in the pwc section Being that his has Pwc engines if im not mistaking
