Here is the situation.<br />1974 Johnson, 85hp. I am replacing the reeds and going with Boyensen reeds. I have talked to people on here as well as a Boyensen reed tech. person on the phone. I am unsure what size jets I will need since I have replaced the stock carbs a while back. The carbs I have now have two numbers stamped on them. The numbers on top of the carbs are: 324859 , and the numbers on the front of the carbs are 324369. I am not sure, but I think these may have came off a 115 hp Johnson, since I bought them used. The jets are .30. The tech said I would need to downsize 5 sizes, but these are not stock jets.<br />I dont know what size jets came in the orginal carbs, or even the factory jets were still in.<br />Based on this information, the reeds are going on a 85hp engine, what size jets should I use? <br />Thanks again.
