Bryant Davis
- Jan 8, 2002
- 24
Ok here goes...About a year ago I built a barge. (For those who aren't familiar, it's basically a floating small house which there are about 20 on the local lake). It is 50' long by 25' wide and floated by 24 styrofoam 4X8X2 blocks. I decided (after seeing a few others) that I am going to put an outboard motor on it to be able to cruise down the shore lines and around the lake much like a house boat. I have bought a 93 model 90hp Evinrude which with the correct prop should get the job done. Here is my question...I have found a console for sale on Ebay which is what I would like to use for all my controls, steering, etc. Is it possible to wire all the gauges, ignition, etc straight to the motor and do away with the control box assembly I got with the motor? In addition, this console has a place for a binnacle top mount throttle control. Will any type work or does it need to be specific to my motor? Don't they make those controls with two levers one being for clutch and the other throttle??<br /><br />Any advice, comments, helpful hints that will make this project go smoother are GREATLY appreciated! Thanks<br /><br />-Bryant
