Hello I have a 1989 force 125 with 2 problems, 1st when I go to start it for the first time after sitting its real slow turning over. If I remove one spark plug and turn it over it starts as it should, I let it run for a min then shut it down re install the plug and normally I can get it to start. It acts like it has to much compression? I checked the compression in all 4 cyl and all read 125 which I think is good. Can I do anything to solve the problem of having to remove the one spark plug to get it to turn over initially? My 2nd problem is 2 out of the 4 times ive taken the boat out the fuel system has seemed to get air or vapor locked and stopped running...to solve this problem I removed the fuel filter/water seperator emptied it out and re primed the fuel system and it started right up. I need to figure these 2 problems out any help is appriciated
thanks mike
thanks mike
