Intoodeeep
- Aug 13, 2011
- 64
I have a 1978 235 using 1988 175 carbs and electronics. The Flywheel is off of the 1988 175. The flywheel I have needs to be replaced. It had to be forcefully removed due to pulled threads. It has four broken magnets and some dents that could be removed by a good machine shop and balancing, but its probably not worth it. Anyways the part number for this flywheel is 582572 which supersedes to a 583844. I have found a flywheel that looks right and at some place found a reference to it being ok to use but can't confirm it. It has a part number of 582573. Will this flywheel work? Can someone please help me on this one? Thanks
