need help with a 1986 force 50hp motor
thads king
hi guys i found my problem with the no cranking or spark on my force 50hp but when i orderd the part i got a round tube about an inch long with two screws in it but i needed a piece about 2 or 3inches long with two screws in the end and two screwsw in the middle p/n should be 87f84449 which is a neutral safety swich is that the replacement part
thanks thad
foodfisher
Re: need help with a 1986 force 50hp motor
Deal with them them. Not much we can do with a faulty order.
thads king
trying to tell if the style of the neutral safety swich was changed thats all
foodfisher
Don't get upset, we're here to help. Some are more versed in specific engines than others. I personally have no knowledge of your engine so my reply was based soley on your wording in the OP. You didn't ask a specific question so I replied as though you were just venting about a fouled up order. Well chosen words will elicit quality responses. You said you got a tube w/two screws in it, my initial thought was, so what.
roscoe
87F84449 is the correct and current part number for Mercury parts.
If you ordered from a Mercury dealer, they should have sent you the correct part.
If you ordered form a non dealer, maybe they sent you an aftermarket switch that they thought would work.
Or, maybe someone just grabbed the wrong part while pulling the order.
Crowleymarine dot com in Denver is your online Merc dealer.
jerryjerry05
What you ordered and what you got????
A few pics will help a TON!!!
Sometimes(unless actually broken) a bit of WD-40 can free it up.Again pics!!
Looking up the part# doesn't always show a pic.
