Need Help With A 1972 Mercury 1150 115hp Thunderbolt Outboard pics added
chevyfany2k2
new guy here who really need some help getting a mercury 1150 115hp to stay running, it will only start if i spray starter fluid into the carbs and will only stay running in neutral for about 10 secs but when i do start it and put it in gear it stays running until i put it back into neutral i have had the carbs cleaned,new gaskets replaced so i assume it might be the fuel pump also on the right side when you take the cover off the motor towards the top there's a place that a hose would go but it's been tap off, the hose is still there and it does have vaccum when its running and at the bottom there's a place where a hose would go and its not tap off and when you start it i see gas coming out of it, i know it sounds stupid but any help would be great i hate to just give up and sell it as parts
jack
Jeff_G
Re: Need Help With A 1972 Mercury 1150 1115hp Thunderbolt Outboard
Should be a recirculation hose. A very small hose that puts additional fuel/oil to the top bearing. Just put the hose to each fitting top to bottom.
Post back what happens after you reattach the hose
chevyfany2k2
hi jeff, might be better to take a picture of it the small hose does fit the top but there's no hose on the bottom just a place where a hose would go and i do see gas spray out of it when you turn the switch, i notice you are from south carolina too i am from myrtle beach,sc i am going to change out the plugs next to see if that helps
jack
Chris1956
Jack, That motor will have a small hose from the very bottom of the block to the very top of the block. Replace it if it is broken.
You might check the idle pickup timing on that motor. When the carbs just start to open, the timing should be 4-6* BTDC. Also, the idle stop screw above the distributor may be set a bit low, causing a stall at idle.
chevyfany2k2
hi chris,thanks for the info but here's the pictures of what i am talking about, the first picture is at the middle and you can see the hose on the right bottom that i assume hooks up to the place thats tap off, the second picture is at the very bottom where i see gas spray out when you turn the switch which i do not see any hose that hooks up to it,lmk what they are for since i am new to these type of motors
Chris1956
Re: Need Help With A 1972 Mercury 1150 115hp Thunderbolt Outboard pics added
I could not see the pictures. Perhaps you can repost.
chevyfany2k2
chris,not sure why pictures are not showing up on your end, i can see them fine, i will try to pm them to you here in a few
jack
Chris1956
Jack, That motor has twin fuel pumps. That is what you are looking at. Each fuel pump has fuel in, fuel out and a pulse hose to the crankcase. Obviously the PO had some issues, since not all the hoses are connected. You might rebuild or at least inspect the fuel pumps..
As I understand it, those hoses with the crimped brass ends are hard to come by. You should switch over to standard brass nipples, standard fuel lines and hose clamps.
Chris1956
My previous advice was a bit off. Look up the fuel pump on the crowleymarine.com web site. It appears that the top fuel pump has the three fuel hoses, and the lower fuel pump has two hoses. Both are mounted on the transfer covers, which provide the pulses to operate them.
Bob_VT
PLEASE stop using starting fluid!!! You can use an oil can with pre-mix in it. The starter fluid does not provide any lubrication and can harm the cylinder walls.
Yes it appears as if your pulse line is not connected.
chevyfany2k2
chris, big thanks on the info, that may be why i have trouble keeping it started
bob, thanks for the info i won't use the starter fluid again
jack
