I recently fixed an '89 Gamefisher. In doing so I loosened the coil for the pull start. The cord then became tangled on my second voyage. I now completely let it untangle and figure if I can just get it back together, it'll work. Does anyone know how to get the coil tight enough and keep it tight while putting the housing together? I had to take this apart as the nut on the end of the crank shaft was loose. Is there a known trick? do I take it to Sears? Any help would be great. Thanks folks.
