need help w/94 waverunner!!!
revedup04
i have a 94 yamaha waverunner 3. it was givin to me from a friend that couldnt figure out what was wrong with it. he said that when it was in the water it would take off then bog out after about 30 seconds. i got it and hooked it up to my hose and found out that there was water coming out of the water lock. is this also the muffler? there is a crack down the side.would this cause it to bog and not run right besides the leak? can i get rid of this box or find a cheaper alternative? i appreciate any advise. thanks tim
eaglejim
Re: need help w/94 waverunner!!!
Mine boged out last summer(last day of riding).We rebuilt the carbs and put new gas filters on, works great now.Jim
tjflan
Hello, I'm brand new to this sight. I have the exact situation as you with the 94 yamaha waverunner 3. I'm pretty sure that I've narrowed it down to needing a new waterbox. I was just curious as to what fix you came up with. Also, if you purchased a new waterbox, what did you go with??? I would appreciate any info you might have. Thanks, TJ
tjflan
Just curious to your fix for the yamaha waverunner 3. thanks so much, TJ
