need help to get more speed
tomisolomi
I have a 1990 Cajun Tournment Series bass boat with a Mercury 150 XR2, it has a Ballistic 14.75 x 15 prop set 3" below pad. I can only get 41 mph gps speed tach shows rmp at 5600. Will changing prop help?
oldman570
Re: need help to get more speed
Changing the prop to more pitch will lower the WOT RPM's and not gain you more that 1 or 2 MPH for every step up in Pitch. It will also make the hole shot slower. If you want speed you will have to probly go with a bigger motor.
OLdman570
jimmbo
You say the ventilation plate is 3 inches below the pad? If it is,it is way too deep, you could raise the engine 5 inches with no worries. Scrape the Ballistic and get a good prop, Mercury makes several lines. Also your pitch is too low you SHOULD be able to run at least a 21.
