Re: Need Help Stiff Steering
'Mornin'Ghostrider,<br /><br />I'm a bit confused by your post. Is she "pulling" hard to one side or the other OR is she just stiff to move.<br /><br />Is this a new problem or something that has existed for a while?<br /><br />If she's pulling, you can trim it out with the tab on the bottom of the Anti-ventilation plate.<br /><br />If it's stiff, disconnect/loosen the steering rod from the tube and determine if it's the steering mechanism or if the motor pivot is stiff. <br /><br />If it's the steering mecanism/cable, you godda CLEAN and lube the stearing cable, rod, etc.<br /><br />Good Luck<br />HAVE FUN!
