Re: Need help removing Flywheel
It's not what the pros on the list would recommend, I'm sure, but I suggest you try to troubleshoot the charging system without removing the flywheel. If the issue is in fact the charging system, I would try to swap out a rectifier first (or test the existing one).<br /><br />Getting a flywheel off can be a real bugger if you don't have the right tools (I don't), and getting it on and properly torqued can be difficult too. I do it, and of course you sometimes need to, but I prefer to avoid it if I reasonably can.
