Re: NEED HELP REAL BAD!!!!!!!!!!!!!!!!!!
gee wizz, you sound paniced!!<br /><br />Never set points on that model, but since no one else spoke up, I'll try and help. I can't imagine its any different than any other small engine. <br />>remove flywheel<br />>rotate engine until point cam is on its highest lift(points are open their widest)<br />>adjust point opening to .020"(unless spec is otherwise)<br />>do this for both sets(reposition cam to high spot)<br /><br />be sure to apply some cam lube to the point cam if this is a new install.<br /><br />hope this helps?
not sure how much detail needed?
