Hey, everyone!
So, quick background:
Found a "good deal" on '86 Bayliner Capri 19' w/ AQ125B w/ 270 outdrive. It was "almost" completed project. According to seller he bought it in crappy condition couple years ago & started restoring it. Replaced floor & carpet, re-upholstered some panels & some seats. Couple weeks ago just before I picked it up he "serviced" the motor (there is fresh oil &coolant in it). But he never started it because he didn't finish the project.
Problems:
1)No start/no spark
First it didn't crank, but I jumped the neutral safety switch & now it cranks but no spark. We traced & checked wiring, found out the points weren't working. Replaced them with HotSpark module. It seems to be working because it sends power back to coil, but still nothing coming out of the coil. I assume I need a new coil, but we tried another new coil that is just below the specs required by HotSpark, but we thought we try anyways (according to HotSpark if coils resistance is too low it can cause misfire when module overheats, we were cranking literally for a 1-2 seconds at a time) just to see if we get spark. Still no spark.
We are ordering a new coil, but I wanted to see if you guys have any input on this? Fixed
2) Fuel tank was full with water that smelled a little bit like gas, but certainly it was not gasoline. I was easily able to put out fire with it... How does a 18-20 gal tank gets full of water? Vent out let in the back? Idk...
3) No fuel was spraying into carbs when cranking.... Possibly bad fuel pump? Jets clogged? I still didn't get to figuring that out, working on ignition now. Works now.
4) Forgive me if I don't know the right terms; I've never owned inboard/outdrive before. I'm missing couple of parts. One is the very last part that connects outdrive to steering. I have everything on the inside that goes to the back of the boat, but not the part that connects to outdrive. Let me know if you want to see a picture.
I looked up parts diagram and it seems like the part is called yoke, almost y-shaped type of arm, but when I looked at the outdrive I couldn't figure out how a part of this shape would connect there.
5) Another part(s) missing is for tilt (or trim, still don't know the right term). There is nothing that looks like it would lift outdrive. When I push the button on the dash I heard a motor or solenoid working in the back, still didn't get a chance to look in the back what's actually moving. Certainly not the outdrive. Figured it out!
I'm sure I'll have more questions later, but these so far are the one I have on my mind. First I want to make sure the motor is good....
Problems:
1)No start/no spark
