Need help installing fuel flow sender
rocstar
I am installing a Lowrance fuel flow sender to hook up with my GPS console. The unit says to install it vertically with a filter upstream. I have a '84 Sundancer, so I was planning to unhook the fuel line at the fuel/water separator, and then extend it so the line starts at the floor and make a vertical run up to separator (right now it is sloped down from the fuel tank). I'm not sure what type of filter to use so I don't have fuel starvation problems. I also want to make the filter easily replacable with minimal spillage of fuel.
Any suggestions?
