erikjohnnelson
- Jul 15, 2005
- 18
I have a 1994 Shoreline trailer. The brakes were not working so I looked in the master cylinder (says Atwood 171 on it). From what I could tell, it had water in it which has caused the master cylinder to rust inside. I found a new master cylinder for $76.11 online. This seems like a fair price. Not sure if it includes the rubber boot that goes on the front of it and brake fluid filling cap. Both are in rough shape so they need to be replaced as well.
I am trying to keep the cost of this repair as low as possible. I removed the brake drums. The drums look ok. The brake shoes look like they have a quarter inch or more left on them. From what I can tell the brake cylinders (have 814 stamped on them) are not leaking. Given that they are not leaking I am hopeful that I will not have to replace them.
At this point I am planning on purchasing a replacement master cylinder, install it, completely flush the brake lines with new fluid/bleed brakes and hope for the best.
I am towing this trailer with a F350 so the brakes do not need to be incredibly strong as the truck does fairly well do the heavy duty brake setup it has.
Any suggestions from someone with experience working on inertia brakes would be greatly appreciated.
Erik
Erik
