sinlessearth
- Oct 28, 2023
- 11
First time posting but have been reading alot on my Alpha 1 Gen 2 sterndrive, 98+ version. I have gear oil leaking out the water intake and have decided to replace the carrier seal below the impeller. When I got the lower separated from the upper a piece of black rubber fell out. Pics attached. Is this supposed to be there and if so where. Any ideas where this came from? Maybe this is what caused the problem?
Another question, the guide tube for the water pick up is melted. I could use a heat gun to fix it but will likely buy a new one. This leads me to my next question. Should the pickup tube from the upper be glues in or anything? It just sits in there but comes out real easy. Thank you all for any help. And thanks to all the info provided on these sterndrives.
