Need Help.Force 125 OB.
BRAVO77
[/I][/B] I Have a 1987 Force 125 hp O.B. The Upper Carb is dumping fuel out. I replaced all of the gaskets, the float needle and Float. ( New float is solid plastic and can not be adjusted ) In have tried everything I can even adjusted the old float needle prongs and I Can Not get the fuel to stop flooding out. Please help. Thank You. JP
jerryjerry05
Re: Need Help.Force 125 OB.
Get rid of the new float.Go back to the old.
The new plastic, I have not found a carb they will work in.
Compare the new needle to the old.They might not be the same size.
