need help for model and serial for force 50hp.
buckeyb
Hi ,Ihave a 1989 force 50hp and need to replace the water pump impeller, impeller plate , water pump housing seal and the boot for the shift rod where it enters the gear case. Every site asks for the model and serial# but the sticker is wiped clean so these numbers I do not have. I have pictures but not sure how to attache them, could use some help there too.
jerryjerry05
The boot for the shift rod????
No boot but usually a seal?????
All the 50 lower units used the same parts for the basic stuff.
Use this # ~~H0508M89B it will get you all the stuff you need.
