Re: Need help finding Johnson part #s
Some times the spark plug wires break between the coil and the plug. If this is the case you may be able to solder a new wire to the coil. These coils do fail, how ever, I have found darn few. Yes the coils can be tested if you have the proper equipment. I don't. You may be able to find an older OMC dealer, repair center or the same in a small gas engine repair shop. Ask the if they will test the coil for you for a couple of bucks. Try to pick a time when they are not up to thier ears in alligators. When you cleaned the points, did you also clean the little bake-a-lite sticks and thier run ways? This is by far the most common problem with this ignition. The little sticks get stuck. Sometimes not allowing full movement. You will want to be careful working with this ignition stuff. These parts are sort of tough to find NOS and I feel are too costly when when you do. Very easy to toss $200. into a $50. motor. Also be careful with the carb. The good news is, just about every garage in America has one of these motors in it or behind it. So used parts are plentiful. The only problem here is, you can't seem to find one when you need it, sort of like deer. Any way keep monkeying around with this coil, let me know what you find.
