browning_gold_12
- Mar 13, 2009
- 19
I have a 1984, 35 Johnson, J35TELCRR. The lower unit has been changed to an older around 80 or 81. It has the Clutch with 2 rounded dawgs instead of the more common 3 squared. My pinion p/n is 322079, thats the only one i can remember offhand.
My pinion has a grove worn in it where the thrust bearing runs. I was thinking about building it up with brass or steel, and machining it back down. Ideas on that?
Or, replacing the pinion only. the forward and reverse are not in real bad shape. whats the school of thought on 1 new gear and 2 old ones running together?
I was thinking of just replacing all 3 gears and the clutch. But i cant seem to find a gear set for it. everything seems to be 1987 AR AE AT only. not sure what that means. any idea where to find a set? or would teh newer style gears fit my housing and shafts? HEEELLLLLLLLLLPPPPPPP!!!!
