Need help figuring out which rebuild kit for trim/tilt
gunner76
I have a 2003 F80TLRB that the trim seeps a little oil from under the threaded cap the lift shaft goes through. I'm thinking the big o ring under that cap is bad. I looked on a couple sites online and can't figure out which kit I need or if I should just get the one o ring. Also looking for an economical wrench to remove the cap, I'll probably only ever need it the one time so I don't want to spend a bunch on it.
tblshur
Gunner76 most auto parts stores have the spanner wrench also when you post a problem and don’t get a timely response you need to re post or bump your post back to the top of the list and post your progress hope this helps :joyous:
