Need Help Fast!!
Bayliner01
Ok, after a long winter I finally uncovered my boat, and after charging and installing the battery i found that my tilt and trim doesn't work. All of my other electronics work, so i know it's not the battery. I'll admit i'm not very knowledgeable when it comes to engines and stuff like that, so any help or suggestions are greatly appreciated. Also,I'm hoping to attend a 4th of july party on the water which is this sunday, so i need to either fix or get it fixed fast. BTW it's a 2001 mercruiser 3.0 liter sterndrive. -thanks in advance
crazy charlie
Re: Need Help Fast!!
Try the trailer button if you have one.Do you hear any noise or clicking???Charlie
texomatom
Could you have missed the battery lead from the trim pump to the + post?<br />Edited to add:<br />I guess there wil be a + AND - lead there ;-)<br />Tom
Bob_VT
I would bet that it is corrosion... Cape Cod salt water...<br /><br />Remove (one at a time) all your electrical connections and sand each one off with plumbers cloth or 220 grit sand paper. After connections sit they naturally corrode.<br /><br />I would do that maintenance to ALL the connections - even the ones that are working.<br /><br />Bob
crazy charlie
It surely sounds like something is not getting juice to the trim motor.As stated,check all connections and check fuses.Make sure battery switch is on.Make sure all connections at the battery are clean and TIGHT!! And post back results.Charlie
outboardguy
Originally posted by texomatom:<br /> Could you have missed the battery lead from the trim pump to the + post?<br />Edited to add:<br />I guess there wil be a + AND - lead there ;-)<br />Tom
I agree you probably missed the trim cables at the battery.Look around the battery for the red and black cables they should be about 8 gauge wire.If they are hooked up look at the power trim motor and make sure the three wire(bullet)connector is pushed in tight.Then check the fuse at the trim pump.You should have something if that all checks out.
