NEED HELP - Engine Flush
masoptions
I have a 2001 5.7gs IO. The boat is in the water 100pct of the time. I would like to flush the salt water out after use. Does anyone have any suggestions? I heard that perko makes a unit that installs online with the raw water hose?
jerryjerry05
Re: NEED HELP - Engine Flush
There are a few flushers out there.You can go as simple as a T in line.Or spend $500.
Check the different options and decide what's good for your motor and what results you want.
A closed cooling system is a good bet too.J
