need help DF115 Suzuki power issue
codfishhead
DF 115 Suzuki won’t start or trim
Started by leaving lights and stereo on all night. Battery went dead. I put a charger on and set it to jump start to try to start the engine. Did nothing not even turn it over. I then replaced battery since it was old. Now the engine isn’t getting power nor does the trim work. Everything else on the boat besides the motor and trim work. When the key is turned on the gages flicker. When I was at the engine and tried to trim it from there I could hear a click in the engine when I pushed the trim button. I’ve checked every fuse I could find. Under the console, next to battery, and in engine compartment in the fuse box. All look good. I’m wondering if I burnt a fuse or something when trying to jump start it. Although I can’t find anything.
Any guidance is much appreciated.
Thank you
Jay
airshot
Check for corroded connections !!! Clean them up to brite and shinney and retighten. Areas of big amp draws need good clean, tight connections
