I have a 1997 40 manual operated 4 cylinder outboard. I have disconnected all of the kill switches and can't seem to get a spark out of it. Is there any check I can do with a common volt/ohm meter to checkout the powerpack or to see where the spark is failing. It originally was running fine, then it died and doesn't seem to want to start again. After about 30 minutes of pulling on the rope it started briefly then died and will not start again. Can anyone mail me a wiring diagram of the harness for this unit?
