Okay guys, I have a 1990 Johnson 140 VRO. I am switching from a 71 Evinrude 135. I have hooked up everything that I know how. this motor is a lot newer and has power tilt and trim. I have the throttles hook up and the power cable big red one from the throttle hooked up. I have the VRO oil tank with a hose with the screw screwed in at the end and a wire. Where do they go? I don't see anywher to plug them in. Secondly where do I hook the battery up two. My old motor had the postive and negative wires comeing right out this one does not? Also I have the power tilt and trim, green and blue wires coming out of the hyrdaluic cylinder do those go to the battery??? and a second coming out of a hole wite and black. If you guys can help would greatly apprecaite it. Or someone wants to talk me throuhg it would be very helpful. Or at least tell me what to look for?? ]<br />Thanks,
