Strauser24
- Mar 6, 2005
- 38
Here you have a 1984 johnson 115 vro, I took it out about a 4 days ago, it started up and ran every time i shut it off,although the idle was fast, so i went by the manual to adjust the idle. I was getting it ready to go out on the lake in the morning and when I hooked up the muffs and tried to start it, it tried to fire but didn't. I then pulled out the plugs one at a time and found that all 4 of them were soaked with fuel, I then dried them off and cleaned them and set the gap to .040 and checked the spark and had good blue snap. then i installed them and tried to run it, it did start and idle at around 850-900 rpms, i used the warm up lever and reved it a few times and it reacted great. i then shut it down and it would not start after that. i pulled the plugs again and once again wet,wet,wet. i also have fuel dripping out of the exhaust. anyone with some help it would be great, i am trying not to goto the dealer. i know that i need new plugs and wires but other than that.. i need help.
