extreme731
- Jun 13, 2010
- 10
I was riding the ski Seadoo Hx at full throttle then it died... i turned it back on and only way i got it to stay on was at full throttle but it only ran at an idol and very cappy at that.. the motor sounded like it wasn't getting gas to me. So i took off all of the gas lines made sure there was nothing in them.. by passed the fuel on off reservoir switch.. checked compression ( good in both 140 to 150 psi ) checked spark Good .. took off the air intake over the carburetors looked at them and it seems that only the second carb is getting gas.. which does not make since beacuse the gas line goes to the first crab an that feeds into the second.. So i thought the needle was blocked or something in the first carb was going to buy a rebuild kit and do both of them.. But my friends papa said he thinks its a timing problem .. Need help thanks
