kneedragger
- Feb 1, 2004
- 61
I have a bone stock '96 GSX with about 190-195 hours on it, that we have owned since new. I have been religous about changing the rear pump oil & seal once a season.
Recently within the last couple of hours, it has developed a symptom where it will not accellerate out of the hole. It will hit the rev limiter until it reaches 3/4 plane and then will "hook" up and accellerate as normal. Then it will run WOT just as normal.
I have looked in the intake and exhaust side of the pump, and do not see anything abnormal or obstructions.
Is this a Wear ring, or how can I tell if my shaft splines are slipping? Are shaft spline slippages common? If so where should I look--impeller, or drive end?
Thanks in advance
Thanks in advance
