Need help 87 johnson 15hp wont start
Bass86
Hello all i have replaced parts on the motor i replaced the power pack and replace the charge coil and spark plugs on the plugs to motor.
its a 1987 (j15rcud) 15 hp Johnson. Now we get good spark and compression on the spark plug side but my buddy thats working on it said its very little compression on the carb side he said the carberator is cleaned and everything but i talked to another guy and he said he thinks it needs a carbjob so im stuck is their something on these motors that make it not start? My buddy pull and pull and he said the pin in the carb dont pop up to spray gas. Also the plugs are not getting wet to make a combustion to start. Any info u guys think that will help will be greatly appreciated.
flyingscott
try spraying a fuel mix into the carb and see if it fires. What do you mean by compression on the carb side? What pin is supposed to pop up and spray gas? Are you talking about the needle and seat on the float? If that is stuck you need to clean and rebuild your carb. Your motor has a choke flapper they do not spray gas.
Bass86
Would the fuel pump have anything to do with it not starting?
flyingscott
No the fuel pump does not start working until the motor is actually running. Describe your starting procedure.
