Need help 1998 Evinrude 150 xp
wooaaday
Hello!
Im pretty dumb when it comes to boats so this is probably a simple question to answer. Theres a valve on the motor that I have had to turn to get the motor started and was curious to know what it is. You can see it in the photo its red. Can somebody please explain what it is and if I need to leave it in the position like it is in the photo I got online. The picture im posting is not a pic of my motor. Its the same.exact motor though. When you unscrew the cap it looks like a valve stem to a tire. Please excuse my ignorance!! Also my boat tends to die when im idling but when I give it a little gas its fine. Thanks!
dingbat
Hello!
Manual primer. Leave it where it is
The valve is used to hook up a can of Evinrude engine tuner to decarb the engine.
High suggest you get a maintenance manual for the motor
