tim chappell
- Mar 11, 2006
- 2
I just bought the boat.The motor fired right up and runs good.At a idle the motor shoots water out the two holes in the back and up to about half throttle,then it seems to disappear.the overheat alarm never went off.Is there a way to test the alarm to see if it is working.<br />2nd question<br />the trim works to pick the motor up and down but when you get it on the water and try to trim it out the force of the motor pushes it down,how can i fix that.<br />3rd question<br />I see reading some of these post people added pee tube to make sure their motor was getting water, how can i add one
