Need help 1970's Evinrude 90hp " No fire on all plugs "
Hammer6950
Hey guys, I'm getting no fire on all 4 plugs on my older model 90hp Evinrude. Assuming that all 4 coil packs & both power packs are good & have not went out at the same time, what should I check next ? I have a strong battery, & the motor is turning very well. The motor was running fine 6 months ago. Any help would be greatly appreciated! Thank you!
By the cowling it looks to be an 81 model.----Some will argue.-----Charge battery.----Load test battery.----Take starter apart and inspect.----Do ohm check on armature.------If ohms check good the assemble and test for spark.----No coins spent doing this investigation.
Hammer6950
Okay, thank you so much. I will do this and respond as soon as possible!
oldboat1
Can try jumping from your vehicle. Pos to lug on starter, neg to mount. May not be spinning fast enough.
tphoyt
Do you have a safety lanyard? If so check wiring to be sure its working properly and not grounding out your spark.
Hammer6950
I took the starter off, everything looks good. Flywheel is spinning very fast, but still no spark. Thanks.
Hammer6950
I do have a safety lanyard. Safety kill switch looks good & seems to be working properly. Wiring also looks great. Thanks.
tphoyt
I’m not try to be a wise guy here but seems to be working doesn’t tell much of a story. Did you test the switch and wiring with an ohm meter to be sure it is working?
Just replace the stator and timer base.----These are the only parts that could be the issue here.
