Hi guys, 86 120 looper. Started running funny all at once, lacking power. I replaced the plugs (new) and noticed that one of the plugs had no color on it after running for 15 minutes, the rest looked as they should. So I know that one cyl is not firing. Compression checked and good, all holes 125 psi.
I swapped a plug wire from another hole and then had it firing on that cyl so I assumed it was a wire. Replaced with a new wire and still have the same problem in the same hole. It seems to be intermittant, meaning once in a while it seems to be firing but mostly not, probably why I thought it was fixed when I swapped a plug wire from another hole. I installed a clean new plug and still had zero carbon or color on the plug after running it. So where do I go from here?? coil pack for that plug? then what after that. Please help me work backwards from most obvious on.
Thanks in advance
Thanks in advance
