Need Elder 6hp Johnson information
ricl
Have obtained an elder Johnson 6hp motor. Been in storage for ten + years. Cleaned up well, runs with help from starting fluid but will not continue to run. Question; clogged Carb? Also trying to establish the vintage of this thing. Model GR-69M, Sn J3049426. Any one have a similar unit? Want to get a manual but need year first. Thank you. See ya!
boatmotor
Re: Need Elder 6hp Johnson information
Hi ricl Your motor is a 1969. Do not use<br />starting fluid, use WD40 - no lub. in<br />starting fluid. Regards Tom
ricl
Thank you Tom for the info. It is greatly appreciated. By chance know if the mix for this old dog is 50-1 or less? Thanks, Ric
