Need compression and carb settings info 1998 Evinrude 115hp
speed_demon
I have a 1998 Evinrude 115hp (60 degree) outboard and I'm looking for a few specs. Compression, idle mixture screw (default turns out), and possibly instructions to fine tune the idle mix from there.
Faztbullet
Compression should be about 95psi and carb setting id 5-1/2 turns out.YOU CANNOT ADUST ON MUFFS!!!! Boat has to be on water, in gear and untethered to adjust
speed_demon
I'm glad you said 95psi! I heard loopers test relatively low but I was still worried when I got 96-101psi dry. Is 95psi optimal or minimum? As far as adjusting the carb is it the same for the jet model? In forward, untethered?
So, adjust to highest idle and richen a half turn of something like that?
speed_demon
Thanks. For anyone looking for the same info I'll save you some time.
CARBURETOR MIXTURE ADJUSTMENT
• See Figure 76
Each individual carburetor body contains either an adjustable idle mixture screw or a fixed orifice, depending on the year and serial number of the powerhead. A fixed air bleed orifice, found immediately above the idle mixture screw or orifice, controls the intermediate mixture. A fixed orifice in the fuel float chamber controls the high-speed mixture. The single float fuel chamber maintains the proper fuel level in the carburetor bowl for all power settings.
• For models not equipped with any mixture screws, see a knowledgeable Evinrude/Johnson parts counterperson for information on alternate orifices to compensate for high·altitude operation.
On models equipped with an idle (low speed) mixture screw, the. carburetor idle mixture can be adjusted to compensate for changes In the fuel system due to carburetor rebuild or replacement or ~hang~s in operating conditions such as moving from sea-level to high-altitude. In order for the adjustments to occur properly the motor must mounted on a . launched boat that is operating and unrestrained. You'll need an assistant to safely navigate the craft while the adjustment is being made.
• If the engine is not operating under normal exhaust back·pressure (which occurs from the gearcase operating under normal conditions, submerged below the transom), mounted at a normal trim angle, with the correct propeller installed and the boat unrestrained, proper mixture adjustment will not occur.
This adjustment is NOT a periodic maintenance item and should not be touched unless all other attempts to resolve an idle speed operation problem have failed. The ignition and fuel system components must all be in good condition and operating properly. The carburetor linkage must be properly adjusted before attempting this procedure, for details please refer to Timing and Synchronization in the Maintenance and Tune-Up section.
1. With the engine top cover removed for access (and, on most models, the air intake silencer as well), make a matchmark between the carburetor body and idle mixture screw. . 2. Start the engine and allow it to idle until normal operating temperature is reached. . 3. Once warmed, shift the engine in forward and run at Idle speed for 3 minutes. 4. If the adjustment is too lean, the engine will sneeze and backfire; to correct this, note the reference mark, then rotate the idle mixture needle (low speed screw) 1/8 turn counterclockwise. Wait 15 seconds for the . engine speed to stabilize before turning the screw again. Turn the screw until you reach the highest steady engine speed. 5. If the adjustment is too rich, the engine will be rough an unsteady; to correct this note the reference mark, then rotate the idle mixture needle (low speed'screw) 1/8 turn clockwise. Wait 15 seconds for the engi~e speed to stabilize before turning the screw again. Turn the screw until you reach the highest steady engine speed.
6. Allow the engine to run at idle in gear for 3 minutes, then move to the next mixture screw. Repeat until all carburetor body screws have been adjusted. . 7. Run the engine at or near Wide Open Throttle (WOT) for 3 minutes and then reduce speed to idle, leaving the motor in gear. The motor should not stumble, spit or backfire. If any of these problems are found, repeat the adjustment procedure, making small adjustments only, until the engine operates normally.
LK_Shastina
Good refresher on fuel system adjustments. I bet new fuel injected 4-strokes are a joy to own and operate, especially when changing altitude from sea level to 8000ft mountain lakes.
Gotta ask:
Is that really a silencer on Evinrude carburetors, or a stumble-spit-backfire-flame deflector / suppressor?
I suppose it could be a dual use item. But with the air intake scoop often aimed at the operators feet, tiller arm and especially, portable gas tank, I'm betting it's there more as a fire suppressor / preventor than for noise reduction. Which would also be why the manual choke lever and low speed needle is integral to the plate. Taking off the fire, I mean silencer plate defeats proper choke lever operation and low speed idle adjustment lever arm stop. Idiot proofing.
And obviously, Evinrude's lawyers marketing team would never allow the term "flame" or "backfire" to be associated with their outboards, let alone be listed as an important integral part of their motors.
Intake Silencer sounds like a great selling point too. Especially given Evinrude's old "Aquasonic" "Whisper-Quiet" outboard marketing sales campaign after they exited and thus muffled the exhaust and hid the unburned fuel & oil into and under the water, never to be mentioned again.
As for "Whisper-Quiet, well, the Sportser motors put an end to that nonsense. Not being able to converse with your wife while under power certainly was "Sporty".
Gotta give those old Mad Men marketing guys credit. They were good.
Today, they market direct oil injection as E-Tec. I-Tech would be more appropriate, but Apple probably owns that one, and besides, Evinrude does begin with the letter "E". And by golly, it makes their outboards sound so modern, so "Techie". No carburetor adjustments, ever. Auto-winterization. No altitude problems. 300 hours of operation. before dealer service required. 100 years of 2-stroke polution solved. Nice! If I bought one today I'd be dead before it ever needed service. Unfortunately, my 50y old Rude just will not die. I truly believe it was built so well as to have a 3000 hour service interval. Well, until along came 10%, now 15%, going on 20% alcohol and screwed that all up. About wore my chug-stall-cuss-spit hellfire low speed needle threads out due to that stuff.
Again, good advice.
