Re: need carburator help "frozen in miami'
I'd start by looking for a leak, if its suckin air somewhere its not supposed to be, that could result in the problem you are having.<br /><br />did you change the mixture settings when you did the carbs?<br /><br />a quick "self help" mixture settings method is to do the following.<br /><br />wind the mixture out 2.5 turns and start the engine, run it at fast idle.<br /><br />then start winding the mixture in, count half turns until you reach the point where the engine starts bogging down. remember how many turns that point was.<br /><br />now put it back at 2.5 turns, get it idling fast again, same place as before.. this time, start winding the mixtur screw out, and mark the point where it starts bogging down again and remember how many turns out that tool. (I usually count half turns.)<br /><br />You now have the points where it bogs on high and low mixture, work out the middle point as close as you can, and set the mixture there, thats a good "off the wall" way of getting it fairly close.<br /><br /><br />So, if you started at 2.5 turns out, and wound it 1.5 turns back in, then the inner point at which it bogged down was 1 turn from fully in.<br /><br />likewise if you started and 2.5 turns out, and wound it another 2.5 turns, that makes it 5 turns out from fully in before it bogged down.<br />so the midpoint of that is 3 turns out from fully in. make sense?<br /><br />if you have trouble grasping that, try drawing it on a timeline type of graph, it'd make more sense that way.<br /><br /><br />rgds<br /><br />Frank
