Greetings,
Seems I'm in a bit of a pickle.
History
Now there’s a noticeable vibration
Starting to investigate
ANY THOUGHTS ON POSSIBLE CAUSES?
What steps should I go through to diagnose it?
Brad
History
- No vibration
- The coupler was worn
- Installed new coupler & gimbal bearing
- Alignment tool moves w/2 fingers
- 1000 - 3200 RPM (didn't go higher)
- This is noticeable both when tied up to the dock in neutral
- And even more when on plane
- I pulled the drive and rechecked the alignment- still moves with 2 fingers.
- Noticed the Green Mercury Extreme grease on the drive shaft spline turned gray after only 6 miles - less than an hour
- There’s no noticeable wear on the shaft or gimbal
- U-Joints appear to be intact
- Bad Coupler?
- Bad gimbal bearing?
- Alignment? Had to pry the engine to towards the port side to align
- Incorrect installation of the coupler?
- Bad harmonic balancer? (no noticeable movement while engine is running)
- How about the 18 year old U-Joints? (No grease fittings)
- Would a worn outdrive splined shaft flop around in the gimbal bearing?
Brad
