ron7000
Banned
- Jul 10, 2004
- 498
Drive is an alpha, gen 1, bought 1994. Have only broken it in half for 1st time now to do water pump. Is there an exploded parts diagram floating around?<br />My questions are, as multiple people were involved in the job parts seemed to disappear,<br /><br />on the (5) 7/16 locknuts that hold it together, are there washers present on any?<br />on the one bolt located where the zinc trim anode is, does that supposed to have any washer?<br /><br />do water pump kits come with, or are supposed to come with, the seal that goes around the driveshaft which is located in the upper? It's the one pressed into the upper, which the driveshaft from the lower slides into when reassembling. You can reach it with your fingers. Does this seal or bushing come in contact with gear lube on the inside?
