need advice plzzz. about on board charger
dloveb
I bought a 1994 nitro bass boat. It has a 3 bank xps on board battery charger. Im charging the batteries now. Is the on board charger supposed to feel hot to the touch. Plzz. Someone help fast. Should I unplug it. Or is it normal.
wingless
Re: need advice plzzz. about on board charger
Not a lot of information...
The general rule is that there is a problem if it is so hot that you can't keep your hand on the device.
The charger will get warm / hot at maximum output. It will be hotest when starting to charge depleted battery banks.
Can you measure and post the case temperature?
