Re: Need advice - composite props
I run a pirhana prop on my 15hp Evinrude on a 10ft Zodiac. It works vastly better than the OEM aluminum prop. Less ventilation/cavitation. On the water blade replacement is quick and easy, blades are inexpensive, and no "downtime" while my prop is off getting fixed. The other advantage is that you only need to change the damaged blade, not all of them, depending on the damage. I run into extremely remote areas and have found the Pirhana prop to be a extremely good solution for me. Any tests that I have seen they are deemed to be superior to aluminum for performance, but not up to stainless. Pirhana props may not be for everyone, but for me they are the answer.<br />Just my 2 cents,<br /> Snow.
