I went to put in my new thermostat. the bolts came out with no problems. I put the thermostat in and tried the motor. The one gasket leaks so I went to take it apart again. The one bolt broke about 1/2 inch about the engine block. It did not feel like it cross threaded or was over tight. The bolt was a little rusty.
I went tonight with a set of easy outs. The ones that are for rounded over bolts, not the drill in kind. I had the right size. The bolt broke again right at the engine block. I think I might have got some gasket glue into the threads. I have the drill in easy outs. Should I use some heat on the engine to help with removing the bolt? How would you recommend doing this? Or should I just us the drill in screw extractors and hope for the best?
The boat is still in the water. I did not think that changing the thermostat would be such a complicated job.
Thanks for the help
Thanks for the help
